Where do you all buy new lifters from? Prices are stupid!
jj5428
Member
zzp? texas speed? rock auto? Just looking for a stock replacement mine are making noise at startup. Tried changing oil to thicker and thinner no help there. Also do you reuse rocker arm bolts or just buy new ones from zzp?
Thanks
Pretty sure you can run stock LS7 lifters in these engines as a replacement. May want to double check on that as memory is a bit fuzzy.
The factory rocker bolts are TTY, so your call. Personally for the peace of mind I'd just get a set of re-useable bolts and call it done. Just make sure the bolt holes are clean and dry before installing.
