speedemongtp
When should one consider porting their supercharger? Are there mods that you should have before you do this? Should you only do it if you gonna run an ic? Also when would changing to a N*TB be of benefit?
the bar running across is what you machine out so the entire bottom of the blower is exposed to help with an intercooler. to port the outlet you extend the "V" and take out those little cornor pieces. you DO NOT want to change the size or angle of the outlet.
make a little more sense?
O now i get what you all are doing. Is there any point in porting the outlet if your not running an ic?
