What you guys using for an oxygen sensor wrench?
J7319M
After having that misfire, I know it's just a matter of time before the catalytic converter is toast. I watched a YouTube video on how to do a back pressure test. All you do is remove the upstream oxygen sensor and install a back pressure gauge. You're not suppose to have more than 2 PSI back pressure at any RPM. What's a good oxygen sensor wrench?
Based on most of our sensors being a long body, I picked up the one that is open, the ratchet goes on the side of it.
i understand why, i guess i just never had any issues with it and i had it in/out more than a handful of times.
I've had a few roll in that required the car running to keep the pipe hot in order to get the damn thing out. It's amazing how much of a fighter they can be at times.
There's a nice o2 sensor snap-on wrench I use that's perfect. Its a bent handle and the socket part swivels. If you don't mind spending money that is on something you could use a regular wrench for
Sent from my RM-860_nam_usa_100 using Tapatalk
I'd avoid the auto zone crap, mine flexed open way too much and rounded off my downstream of. I got a decent one from NAPA and it has zero flex.
