NotEnoughGPs
I have a 40th GP GT, with 188,000 miles. Lowered car at 100,000 miles with Eibach lowering springs, KYB AGX struts, new strut top plates, shortened (black) dog bones, anti pogo washers, engine and trans mount spacers, engine and trans poly mounts. Also, GMPP sway bar, F-body brakes, new tie rods, ball joint, control arm bushings. And last year new installed front Moog wheel bearings.
PROBLEM: for the past 8000 miles, I can hear a constant low growl or whirling noise, and noise level increases when turning wheels left or right. More noise when turning right.
Everyone says the front wheel bearings are worn out and possibly the rear bearings could be blamed for the noise also. I just installed new wheel bearings in back of car at about 3000 miles. Noise still exists.
Removed Moog front wheel bearings to double check for wear and they are ok.
This noise definitely is in front end of car, it does sound like worn out wheel bearing noise. Can hear it well at slow speeds up to 40 mph with windows closed.
Then, when going into a turn, low growl or whirling noise increases. The faster I drive into a turn, the more noise there is.
The noise is there when turning whether I am pressing on brake pedal or not.
When driving straight, there is still a low growl, but not as bad as when turning.
Also, made sure all wheel lug nuts are tightened to specs.
The drivers side axle was replaced once. Passenger side is original.
Do you think one or both axles are bad?
Also, read on another car forum that the area where the axles go into the trans could be worn and that can cause the noise when turning.
Any thoughts about what to check next?
