What pulley vs cam?
Timing
Wondering if i should run a 3.5 with the vs with higher timing or a 3.4. What do people usually see for timing on there setups with the vs?
I run the 3.4 with 18* of timing @ WOT but im a L67 Gen3
How much timing are you running on your 3.6 now? any KR?
Really your at 18* on a gen3 with the vs and a 3.4? See thats why im wondering. Who said to use a 3.2(gen3) or 3.4(gen5) on a mild cam. Just seems like running higher timing like your setup on a larger pulley would be better.
When I was S/C I ran a 2.8/XP/18*....I think a larger pulley and more timing is a better setup then tiny pulley no timing.
Realistically... you shoulda been able to run a 2.8 without an IC tho aaron... lol e85 + headers + cam + ic = 2.55 blower maxxed out lotsa timing
Ya they say you can run a 3.2 with the VS and supporting mods which I'm sure I could but probably not with that much timing. it's better to run a bigger pulley that is KR free and higher timing than a smaller pulley with KR. I try to run no more than 18* of timing KR free before I go down.
I say just go 3.4 if it knocks a bit play with the timing and maybe add a bit of fuel where it knocks to combat the KR and she what you can get out of it.
It you end up.not being able to run it you know you can sell it and you won't be out much cash.
