What other GM parts are swappable with 08 GP
Sbcook1911
When I was younger, I could tell you what parts and what make n model to snatch junk yard upgrade parts off of. Brakes, suspension, ect.ect. Now I have a 2008 GrandPrix and it's getting time to start doing some "freshening up" got about 90,000 already no problems at all! It was even driven through a flooded road and stalled out in a nor'easter! It was towed home, pluggs pulled, airbox pulled apart and filter replaced! Started fine and still runs great!
My question to you real Pontiac pros is, what other GM models can I scavenge for better brakes, springs, intakes, and so on. Are there and better GM wheels that fit like GTO? I'm going to need brakes first so are there any bigger/ better rotors callipers, rotor swaps for the rear? Sway bars?
Any and all advice will be appreciated!
the brakes from the Fbodys (camaros, trans ams) and GP GXPs will fit, zzp sells kits and i believe WBS does too. stock springs can be found on the olds intrigues of the same era but not really any "better" ones. as far as intake ur better off just to make ur own, its cheap and you can make it fit exactly how you want. NOW alot of parts are swappable from all the Wbodys like monte carlos, regals, and impalas all depends on which part
