what is the best way get this fix
Soviet
Today I installed a reptile ported tb on my gt and after takeing the old one off I found out the helix tb spacer's gasket[that i put on a year and half ago] was about to give again. I know most people think spacers are not worth anything but I did fell a diffence in respouse and a little power just few horses. Need something that I can trust not to leak I dont need to change the plugs out again because this isnt the first time this has happen.
on the TB to spacer side of an L36.... you can't use the factory gasket because its a rubber insert for the upper plenum. Use RTV.
sounds like I need to just buy some rtv and try it then thanks everyone
and just wondering anybody else have this problem
I've always had good luck with the GM gaskets
Got a question about that the only gasket for the tb is one that fits that fit into the groove on the interior side of the tb not between the two flats sides of the spacer and tb just saying I zzp has one but i tried it but thats the reason I started this post thanks for trying
