what gaskets ?
04lss
Hi all ,
I recently got my hands on a turbo GTP, with the cartuning turbo kit. it has an exhaust leak and i want to replace all of the gaskets. Specifically the rear manifold blockoff gasket, upper to lower DP gasket, and lower DP to catback. Im also open to replacing anything else you folks suggest .
Im assuming that the rear exhaust manifold gasket is just the OEM gasket, even when using the ported rear mani. The ones im not sure about are upper to lower DP, and lower DP to catback. can i just use a normal 2.5 inch exhaust flange gasket?
You will prob need to measure as the gaskets sizes can vary dp is optional 2.5 or 3. Should be able to get all ur measurements with it together still. As far as the manifold gaskets I haven’t had any problems with the oem steel style or the felpros.
