What fuel tester should i buy. (gas/injectors)
Any of the nicer ones from an auto parts store will do.
The test port on all GM's is pretty much the same, so whatever one you get will work with all 3 cars. Most run around 50-70 bucks.
Yeah that's what I used on my 05'. It held for about 4 hours before even dropping a little. even the next morning I had about 10 psi.
Jeff
Also if you wanted you could rent a Fuel Pressure Gauge from Autozone for free. I know the one near me has them for rent.
But then I would miss an excuse to buy a tool. :-)
I hear you, and your are right. :-(
BTW, here are two I am looking at:
1. http://www.ebay.com/itm/361354532399
attachment.php
2. http://www.ebay.com/itm/361354532399
attachment.php
The 2nd one (yellow case), in the lid, bottom adapter, looks like it has a cutoff valve. Is that for isolating fuel pump/regulator to test for leak down? Although one valve would work on the 04+, what about car that have the regulator on the fuel rail and a return line?
There is a delta of about $34.
The only car I have not been able to use my gauge from the parts store is my wife's 01' Nissan Maxima. It would have to have been put in line as there isn't a provision for checking fuel pressure. Any Ford GM and a few other cars have used the 2 different fittings. But get what you like.
Jeff
