What color are my injectors supposed to be?
J57ltr
Ok, so while I'm up here in the Chicago land area, I got to thinking about the issues I've been having with my car (no boost, computer won't allow it) and that the previous owner had done some things to the car. Namely put a 3.4" pulley on my 05', well I changed it out and still no luck. So I started wondering what else had been done to the car. When I got it it was missing the engine cover (nbd I like seeing the SC anyway). When I removed the stock airbox the computer was loose and there was "extra" hardware in inside. So I was wondering if maybe they originally had larger injectors installed and remapped the computer or something. I can't really tell what color they are they are kinda beige but I could see some staining on them. Then again I'm halfway across the country right now and don't remember
Jeff
33lbs
They should be white.. But with age they'll appear a yellow/beige color
Wow, that small? I figured with a returnless non boost referenced fuel system they would need to be damn near 42#. Ok thanks.
Jeff
Most likely.. Generally around the 3.2 mark is where you'll start needing bigger injectors.
Hell, I might take you up on that lol. I am going to take them off and run them through my injector cleaner/test stand and see how far off they are, when I get a chance.
Jeff
