offroadfury6
two rants on this one.
First, I decided to do a tune-up on the raptor today. well I changed the oil, then took it for a ride, when I was done, I parked in the the shed, as soon as I cut it off, SPLASH! all the oil burts out of the bolt hole...WTF! cleaned the bolt and took a close look...Yamaha used "crushable" gaskets! sooo all that expensive yahama-lube is on the floor and the gasket just went to dust. Who the hell would use such?
Second, my bro-in-law brung his Mazda 6 over cause he's mechanically Declined! He had a headlight out. I take the 2 bolts out, but somethings still holding it. look closer, find a plastic thing that locks in. So Ok, I know this one, get a flathead and pry the middle up, then the outside plastic will slide out. did so, only the middle plastic pulled up and then the head of the plastic went flying...
also snappd my only Suzuki key to the motorcyle in half today and it wasn't even in the ignition. (Don't Ask!)
Talk about WELCOME TO THE WORLD OF MECHANICS!!!
