Fahrenheit
So my passenger rear strut mount is bad (clunking in the back and I'm 90% sure its the mount anyways). Figure when I go in and do it i'll do struts and mounts on both sides along with new spring isolators. So this sub forum has a sticky where the guy recommends KYB Excel-G struts, amazon has rear fairly cheap. Plan to use them with the OEM springs unless I find any broken when I take apart the struts. Just looking for something as good as OEM and if it makes the car a little more sporty feeling in the corners then that;s just a little bonus. ACdelco mounts seem to be the way to go since they are affordable along with KYB spring isolators. Do plan to do the front in the spring along with new lower control arms since I got a little bit of a pop from the front end under hard accelerating/braking so what ever I put on the back will make it to the front shortly.
