What are all these gaskets?
piperflyer
Ok, I need a little help identifying these gaskets and knowing where they go. I bought a FelPro gasket set. I had a valve job done on the heads so I have to use the entire set, I assume. Can someone help me out with each of these gaskets? I assume the black o rings are for the fuel injectors.
Injectors O-Rings are the small black circled ones...
Valve Cover Grommets are the blue ones...
Big orange one is the TB gasket
the rectangular gasket goes on the LIM under the throttle body...and the orange rings in the same bag should be the coolant passage o-rings IIRC...
Those other ones...probably some L36 crap I can't remember. I haven't worked on a L36 UIM/LIM since 2006 when I did a UIM swap for my Mom on her LeSabre...first 3800 I ever worked on :D
The injector o rings and valve cover grommets make sense. The other ones I'm not sure if I took them off originally.
