Weird Wistling
crock
Ok, this may sound weird. When I am accelerating with my music turned down and heat off, there is a whistling/ humming on the inside of the car. I am not sure what it is. I can tell you that my heat feels like it is on, but it is not. I just want to stop the annoying humming and the possibility that the heat is on. I can feel the warm on my legs. So my question is what may be causing this hum/ whistle? I do have my car ran for subs, so the little rubber fitting in the firewall is out. Could the heat be coming from there? Thanks guys. Help me! Its not major.... just annoying...
Im not retarded. Lol. I know the difference. When I put it in boost, you can tell the difference. The interior is whistling, not the supercharger...
Arg! Yes I am a pirate. I just want help! Not saying that I have a turbo... Cause I dont. I own the slowest GTP in the world.
Put your ear up next to the blower under the glovebox. My aftermarket one whistles when only turned up a single notch. Maybe yours is getting an itty ibtty dash of power and it's spinning.
Or you have a vacuum leak.
Im pretty sure I dont have a vacuum leak. I might have a bad blower motor... But it even does it when it is off....
I have/had this problem too. I never figured out what it was but it went away and randomly comes back for a couple minutes. Sounds like almost the old radios did in cars from electrical interference in mine. but radio is off and its not coming from the speakers. and its quiet kinda? ide like to know if anybody finds out what it is too if ours is the same thing..
It is exactly like that. It will go away from time to time, but come back later. I thought it was from the speakers on day, but it wasnt.
I never drilled through my fire wall.... all i did was remove the rubber fitting. thats it.... Im not mechanically retarded. I wont drill through a hose...
