Weird transmission issue?
Wes2k8
Recently my van started having a weird transmission issue. It's an olds silhouette with a GTP drive train. It will shift into gear, but when I try to move it feels like the car is being held back, almost like how it would feel if you were driving with the e-brake pushed in, but it is definitely not. One day while it was happening I hit the throttle kind of strong and the transmission sort of lurched a little then started driving normally again.
This has happened a couple times before, but usually turning the vehicle off, or shifting into reverse then back into drive would fix it. Today it's started doing it again, in reverse and in drive, but no amount of turning it off or rowing through the gears seems to fix it. Whenever this issue happens the ABS, TCS, and brake light will be shining on the dash as well.
Anyone familiar with this issue?
I would scan for codes.
Voltage at idle good? Battery Cables tight/clean? It sounds electrical, and the TC is not sure what the f** is going on. Weak grounds, man. On the Battery, grounds to the frame, Ground to the engine. I would check those first. Although, a weak/clogged PCS in the tranny might..... hmm.
