gagt3100
Ok so when I accelerate from a dead stop or roll say about less than 15 mph and floor it the transmission does not seem like it wants to shift it will hit the redline 1-3 times then shift. It only does it in 1st and when it is in D. If I go %90 throttle it shift just fine no shaking or anything. I do have tap shift and when i manually shift from 1st to 2nd and WOT it is just fine no matter where I shift in the gear. I am also currently in the process of installing a nitrous system in my car and right now the only thing I have messed with is the Throttle position wire and the wire seems to be fine but I will 2x check it in the morning. Fluid is perfect pink and full. Any thoughts? Electrical? bad clutch? Should I drop the pan and see? Oh also the rebuilt trans has 11k on it.
Thanks Guys!
Thanks Guys!
