lilredss0287
yes i have the zzp turbo kit with a udgraded t3 to4e 60mm turbonetics turbo and 38mm wastegate and i recently changed the spring...i doubled up a 10 psi large yellow spring and a little red 6 psi = 16psi right?
other mods are diamond 8:1 compression pistons,stage 2 zzp heads,498 lift comp cam camshaft,oe r lifters
but after i put the springs in (also note. im not running a boost controller) i stomp the gas and the car started shaking VERY HARD back n forth constantly until i eased up on the gas a lil bit.....anyone know why this does this??? do i need colder spark plugs? is it my trans? cause i do have a stock L36 trans
ooohh and also when i just had the 10 psi spring by itself in the WG it still did this but not as much
