reallyfast1
So installed 1.8 roller rockers 2 weekends ago and was pretty easy on the engine since and the odd time I get on it and make boost it stutters for a second and was wondering if anybody has had this issue?
I had a rocker get loose...like the bolt was jsut finger tight...and it had play in it.
When I'd get on it...it'd studder.
Take a die grinder...cut a line in the side of the threads...then run it down...and then back it out. Does what a Q-Tip does and so much more![]()
Because there is thread sealant on those bolts from the factory. You'd be amazed at how much gunk comes out of the threads even after using a Q-Tip.
I wish I had pictures of my buddy's rocker install...nastysauce.
Because cutting a bolt is free![]()
