Dee23
We all know these W-bodies are knocking professionals and/or at least inevitable to happen at some point. So I have this lil knocking sound on the driver side that seems to progress more and more. Now it only happens when I apply the brake and it has gotten so consistent that the slightest PSI applied to the brake pedal you hear this clear and irritating knocking sound. Doesn't sound like anything is falling apart but whatever it is its definitely loose.
And I know that sound travels so im sure the sound is coming from the driver tire area but it damn sure sounds as if its coming from the fuel tank area, WEIRD. Ima check the ball joints and rack n pinion again but I also have a strong feeling that the subframe mount bolts may be loose(though they shouldn't be)
But what makes me puzzled is that the knocking sound is directly responsive to the brake pedal, like so responsive that I was driving 5mph purposely applying the slightest touch of the brake pedal that I would hear this sound. Again its barley on take off but constantly while braking(mainly softly which is weird which also tells me whatever it is its super loose or literally hanging by a thread or its last bit of life).
00' regal Gs....every mount or ball joint on the front end is new including all of the subframe mounts nothing older than two years. Anything is possible to go wrong especially with the way I drive but this one is bugging me out
