So I have an 01 GT that I'm about to run off a cliff because I'm so sick of dealing with it. I have had issues with ABS about once every year for the past 6 years i've owned it. I have replaced all 4 hubs in the past 4 months with zzp premium hubs and I still get issues with the ABS lights coming on, and right before they come on the ABS kicks in for a second, not even braking hard, and it pushes me off the brakes. If I have replaced all the hubs, is my only issue some electrical lines running from the computer to the hubs? I also have had a coolant sensor that's constantly saying low coolant, even though it's full. I read somewhere that there can be rubbing on a wiring harness on the driver side from the air conditioner system which can cause coolant sensor and ABS issues, could that be my issue?
tl;dr replaced all 4 hubs with zzp, still get ABS lights coming on, also coolant sensor says its low, but its not. help?
