weird electrical issue oil light on with key off !FIXED!
almighty
so im driving over to help a fem friend change her oil and i turn off the car and it dings at me. i notice the oil light on while the key is off and out of the ignition and it wont turn off. i did notice it turn off once after 5 mins or so. i also am having an issue with the shift interlock and the dash gear indicator not showing my gear, all this happened at the same time. any help would be appreciated
Re: weird electrical issue oil light on with key off
also it appears as if my courtesy does not work as soon as the key is off, and the seatbelt light is on.
quick bump for the morning crew, any help is appreciated
ok, issue was found, the 2 small ground wires on the trans decided to break and they would hang close enough to ground at times. quick fix, new eyelet and re-ground fixed the issue
