Wbody store lateral arm bushings
buckethead92
Anyone know the part numbers for the bushing that come on the wbody lateral arms? I ordered a set from wbody store and they come with the wrong bushing. Now there closed down and I can’t find the right parts.
It’s the whole rod end and bushing assembling that’s incorrect. I contacted ZZP, they didn’t know and ingalls has been bought out by Dorman so there is no contact info for them.
Notice the three on the bottom are different than the rest.
see if the center diameter is the same on the ones that stick out. If it is cut off the steel that protrudes from the rubber. Pound the metal bushing to one side so you only have to make one cut each.
Also be sure it is not a 2 piece metal insert. if it is check for separation. I think they are one piece though.
