I recently have new green coolant instead of the dex-crap and using a drilled 180* t-stat. on the freeway if I do a few minimal spirited driving, not100% throttle but upwards to 75%, my ect would spike as much as 204*F along with the trans fluid(I run a gm auxiliary trans-cooler after the radiator) on a 90+ degree day. Is that normal or is my water-pump not keeping up the cooling process? I do have my fans on at high speed(speed 2) as well. the water-pump’s OEM and the cars at ~149K miles. FWIW on a normal driving around, the ect is around 185-187*F in 85+ degree temps
What’s the correct part number for the water-pump on rock auto? Their site has ACDELCO Part # 252693 for both 2 and 4 door. Also I did a search on here and found no write-up available for installing a water-pump. Anyone care to give me a (semi)-detailed instructions on the amount of work im looking at? Thanks in advance!!:th_thumb-up:
