Ok so I searched and found a bunch of stuff about 97-03 GP's. But I have a 04 GTP compG Here's my problem, passenger floorboard is soaked....and I know where its coming from I just need a little bit of help.....
The drain tube that comes from the sunroof, follows the A pillar down to almost the rocker..
I pulled back the carpet and there is a cutout in the pillar where I can reach inside and grab this tube..
It is not connected to anything and just hangs down.
My question is, where does all the water supposed to drain too?????
I guessing something is clogged...
I've tried everything, even removed the plastic ground effect/rocker to see if there is a hole/drain somewhere and nothing...
If anyone could help I really appreciate it...Thanks in advance.
