water leak in cabin
pitifeo
Hey all. Wondering if anyone else has experienced water leaks into the passenger side of your grand prix's for no known reason. Mine is a 2 door and the weatherstripping around the door is not in the best of shape but the water does not appear to be coming from here. It appears to be coming from behind the glove box and then filtering under the carpet so I don't see it until the carpet suddenly fills up wet. Other times it doesn't appear to come from there like after heavy rainstorm when car is simply parked it will fill with water. It's driving me nuts!! any help would be greatly appreciated.
Buddy of mine around here has the same issue with his 2 door gtp. I'm subscribing for an answer. Hopefully someone here will have some insight.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Fivefingerdeathpunch nailed it with the above link. Had the same problem with my 2001 GP SE about 2 years ago. The replacement deflector was amazingly cheap at the local dealership, definitely less than 10 bucks. Went in quite easily, solved the problem, no issues since replacement.
