Does anybody know if the washer fluid pump on a 03 has a fuse? or if it stopped spraying then the pump is bad? Mine stopped spraying and doesn't even make noise anymore when I try to spray it.
ok cool sounds easy to do and cheap. I looked in the manual for a fuse and did not see one for the pump. Couldn't be on the same fuse as the wipers themselves because they still work. I will look again
The easiest way to replace the pump is to turn the wheels all the way to the right and pull off a few of the screws that hold the inner fender on. Then I think the pump will just pull out of the tank.
Changed the pump today for $16 at autozone and works again. I don't think there is a fuse for this and could not find one listed in the diagram. Could be wrong but just seems like the pump goes bad. Just wanted to update.
on a 97 gtp is the washer fluid pump on the outside of resvoir because there is a little black cyclinder on the side not sure if thats just like a vacum hose or something
