tdm571
I have a 1997 SE with the 3800NA engine. I just completed changing the water pump, thermostat, belt and upper and lower radiator hoses. In the process, got rid of the DEX
th_thumb-up
. I know it is probably a coincidence, but now my windshield washer fluid low light in my analog DIC stays on. The WW fluid reservoir is as full as it gets. I didn't see any fuses for it. Could the sensor have gone bad? If so, do I have to swap out the whole reservoir to change it or is there a way to pop it out that I am missing? If not, where else can I check?
