Warning Light Central, Has anyone seen this?
Definitely need to scan and clear codes just for a fresh start wow that's a Christmas tree in there.
MY compG had traction abs and stability lights, and my scanner read a right from wheel sensor circuit issue. It was the wiring to a speed sensor. i replaced the hubs and nothing. after that i followed the wire and found that it frayed. Fixed it and no more lights:)
Damn matt beat me to it.
Right after i posted tried to start the car again and it would not start (No Turnover at all) but the needles on the dash did their normal movement like on start. I think its a combo of bad hubs and alternator. Installing 2 rear hubs, alternator w new pigtail & battery. Will let everyone know how it goes. I will check for frayed wired thanks for the advice. If all that dont work im gunna check for bad grounds too, had an aftermarket audio system put in about 3 weeks ago, maybe they jacked something too but you would think bad wiring job would rear its head right away not 3 weeks
HighOctaneRacing, That was a good idea until i couldnt start the car again :) I got 2 rear ABS hubs, battery, alternator & pigtail for 315 after cores....seems like a good deal.. The Stealership wanted over a G for all.
After a 2 day debacle with 3 mis-packaged pigtails. Finally got the Christmas tree lights packed away. :) If i had to narrow it down to one major culprit i was the alternator and burned out pigtail. Most likely just the pigtail arcing on the alternator mount from frayed wire. Would have been nice to have testing equipment but hey sometimes its fun to tear stuff apart.
