GTP89
Ok guys finally time to start doing my tranny on the car, I did the build about 3 months ago tranny lasted me about 2 weeks before it gave out. Some of you followed my build I will post some pics to refresh the memory. I do have some questions car ran fine, BUT I want to get the most out of it. First off are ported heads a good benefit on a cam like that? I Have seen the record for the cam and around 360-380whp and I will be happy with about 330whp and above.
Mods on the car Vs Cam, Stock heads right now, 90# springs, LS7 Lifters, Slp Headers, Borla Catback, Gen V 3.4 on 91Oct Tune, Still need my E85 Tune probably run a 3.0-3.2 which ever gives the best result, 60# Injectors, N*, Autolites 103's, PRJ Wires And fuel Pump Rewire, 8 Rib Setup, 180 drilled t-stat, Ported Lim, As far as engine goes I believe that is all. The heads I plan on installing I have in a GTX I purchased = SUpposed Stroked out GTX, I want to take them off that car and install it on to my VS Cam 40th Car.
Please let me know what you guys think, also can I run my 1.6 Yella Terra rockers with the VS Cam if so is it worth it to add them on there? Thanks in advance guys.
