    TIPS:
Vortex Cooler
thegoldenboy
Alright, im still somewhat new and inexperienced in the car world; but one thing i know is that the cooler the air going into the engine, the better the performance.
In talking with my dad the other day about cold air intakes and such, he brought up vortex coolers. I had no idea what he was talking about so i decided to look em up. This is some serious stuff. It's a simple tube with some sort of turbine that separates the hot and cold air. With a supply of compressed air, it can freeze water in no time.
This is one of the best sites I have found on these tubes.
Vortec - Vortex Tubes for Spot Cooling
I dont know where exactly to go from these tubes, but i was thinking maybe a small supply of compressed air that could somehow hook into the intake tubing and make for that much cooler air.
I think im gonna make a phone call or two to the manufacturers and see what kind of results i could expect with a limited supply of compressed air.
What do you think? Could it be done?
A couple of years back I was talking with a guy that invented a vacuum operated vortex tube. I was going to use a signal before the rotors, then plumb the cold side through the pcv. We went back and fourth for a few months, but ultimately he wouldn't share; he had bigger aspirations for the sytem for an oem.
It's a novel idea, but ultimately you are going to be in a dead end with it. The only chance of it working is cooling off the sc case, and since you are using a gas with very little density it won't be at all efficient. Convection cooling like this would take a massive amount of cold air to have any effect.
Just out of curiousity: relative to how much energy/gas it takes to run a regular air conditioner, how much would it take to power an on board air compressor?
or is it basically the same thing?
