Vibration
RICHEYSGTP
I've got 04 gp and anytime I'm on the gas or with cruise set I get a vibration as soon as I let off the gas it stops
I don't really feel it in the steering wheel just in floor board and seat
Car has new brakes rotors calipers tires and alignment. Don't just wanna throw parts at it
There are four. One engine mount, one trans mount, and the two dog bones. The problem child is usually the engine mount because its hydraulic and usually fails.
Sent from my Droid
Ok I've got underneath. The trans mount is dry and looks clean
The lower engine mount has oil/ grease on top of it and all over front of oil pan
Is this what they do when they go bad?
Ok think I got it figured out the vibration got hella bad when accelerating and cornering right at higher speeds I bought new cv axles and tie rod ends
Hopefully the repair goes smooth I've never done cv axles
They leak, but your oil pan gasket leaking is probably what you are seeing.
I'm going to disagree based on personal experience, though I can't say for sure if that's where the rumble comes from. Besides, you'll need a solid rubber lower engine mount to replace that fluid filled one sooner or later... it's cheap, it's easy.
