Vibration issues???
wa04compg
Ok so been dealing with a vibration only when turning right and accelerating new cv shafts and wheel bearings and still doing it just not as bad. Motor mounts appear to be good no leaking. When I changed the drivers shaft the output shaft inside the transmission was really loose and floppy...is that normal? With the cv shaft installed there is a needle bearing that holds it in place but just seemed extra sloppy...am I ok or do I have a issue
Have you checked rear wheel bearings? I had a howling that I swore was coming from the right front, but ended up being the left rear.
all the wheel bearings have been replaced within last 10k...not really a noise just virbates like a mother when turning to the right and accelerating...can turn to the left and got wot no vibration...axles and wheel bearings are new motor mounts aren't leaking...wondering now if could be a trans issue
