ablank37821
Alright to start this is a 2000 GP GT N/A, I recently had to replace both front rotors (they were toast), it solved the vibration I was getting while braking in the driver side front wheel but the vibration has persisted in the passenger front. Now what I find odd is the vibration isn't always there it seems to come and go from day to day, this issue also presents itself throughout driving ranges and what I mean by that is the vibration is there while braking or not at all speeds, it almost feels as though the passenger side tire is ready to fly off but as far as I can tell the hub is still good, the tire is balanced, and the lugs are not loose. Another thing worth noting is at low speeds when braking I can feel the brakes grab and give a little then grab again. The vibration/sound I hear while driving w/o braking is similar to that of a blown tire smacking the ground if that helps. I am not entirely sure this factors in at all but my upper motor mount bushings are in need of replacement, you can move the upper motor mounts with your hand granted it isn't a large degree of motion but enough to visible see it. Lastly the brakes were still in good condition though someone brought up that they may have crystallized. I hope you all can help me narrow this down, I am not too familiar with brake systems. Thanks in advance for any feedback you all may be able to provide.
