T0pwater
Recently I removed my 180* T-stat for gas mileage purposes (stock car). I had used the 180 as a replacement for a 195 stat that was running below 170, thinking I'll need the 180 soon. Anyway, I took that one out and put in a new Stant 195 thermostat and this is what I'm getting:
Temp will warm up like normal to around the 195* range (just before the middle of the gauge), then the t-stat opens and the temp comes down to around 180 - normal, right? Well, it never gets back up to 195. It just fluctuates around 180. This happened yesterday and today. If I sit in the driveway the temp will come up past 195 until the fans come on like it should. The problem only occurs if I'm moving. It's been 50 deg outside where I live.
Yesterday I sat in the driveway and held the car at 2500 RPM until the temp was 210 for about 5 minutes, just to flush out any possible crud sticking between the thermostat plunger and the flange, thinking something got caught as it was shutting. Then, this morning, same problem. All my readings are just coming from the gauge... currently looking for a used scanner.
Any thoughts? Did I get a bad t-stat?
