My 08 GXP has several interior lamps out and I am looking to replace or fix everything and even upgrade the working ones to LED. Heres the list.
Driver Window controls - All the window switches in the pod are burnt out
HUD control dial - Burnt out
Shifter illumination - Burnt out so cant see P R N D M
Instrument Cluster - Dim on the Tach so I assume a bulb or two is burnt.
HVAC controls - Both Driver and Passenger heated seats buttons are burnt.
For the Instrument Cluster I thought about replacing all the bulbs with LEDs. I assume they are 194's. I want to keep the stock color and I am worried that if I replace them with white LEDs the Redness will be a bit washed out. I also considered Red LEDs but dont want it to look bright orange or make an awkward tint. Anyone here with an 04+ done the LED Upgrade without changing the stock color?
Thank You
Thank You
