valve spring seal
blazinzuk
I am replacing a valve spring that broke. It also appears to have damaged the valve stem seal. Just the very upper part. I need to get the car running asap. The lower portion of the seal appears to be in fine shape.
I will try to find one tomorrow but if I cannot will the seal still function with a small portion (less than 1/32") of the seal gone of damaged?
Without a pic etc. I'd say you are taking the chance of it leaking a little oil into the cylinder. The good part is that you can burn a little oil w/o any real issues until you can order a set of seals and get back to 100%
I would get some seals. Any machine shop that does head work should have some.
You sir are correct, this is supposed to be my nice don't work on it too often car and I am sitting here thinking about doing something halfway.
Time to source some seals hopefully someone local has some
