DanPrixGTP
Moderator
As many of you know, my engine bay is in need of a black Valve Cover. Luckily i have one sitting on the shelf.
Ive tried a few times to remove the coil pack bracket but i keep getting stuck. I know its something simple and thats why i posted this in the "Noob Questions" thread.
I remove the belt, remove the tensioner and idler pulley, remove the dog bone.
Blue Arrow: Ive removed this bolt.
Red Arrow: Ive also removed this bolt that grounds the ICM and the alt brace is connected too.
Yellow Arrow: Here is where im stuck. Ive heard this bolt inside the tensioner assembly needs to be removed, by the looks of it, its a hex bolt. Well i dont have an inverted torx bit to remove it. Ive also been told its just a bolt, so slide a socket in there and remove it like normal. Well i have put in multiple socket sizes and none seem to fit properly. Is this the third and final bolt that needs to be removed, if so, how do you go about removing it and what size socket do i need? Thanks.
