Loftus1995
I am trying to finish up my build, a few more parts but I am stumped on how vacuum works with turbo boost. I have seen online that a few builds have one or two vacuum blocks. I currently only have one but I may have been unprepared when trying to figure all of this out. I am following a diagram on Autozone website, obviously this doesn't include the turbo vacuum lines I will need to run.... Just looking for a little assistance on how I need to run these lines to one/two blocks.
https://www.autozone.com/repairinfo/...00c15280217d39
Attached are photos as well, as what I believe will need to be hooked up to the block.
First photo: Throttle body
Second photo: Intake manifold
third photo: I believe this is supposed to be a breather but am not 100%
fourth photo: Master Cylinder, also can this be to the block or will this have to get it's vacuum directly from the engine?
fifth photo: Lower intake manifold, again not sure if this can be blocked off or if i will need it
sixth photo: fuel pressure regulator
final photo: This is on the exhaust side of the turbo, now does this go to the vacuum block or how do these connect?
Again thanks for any help, I just want to make sure I am doing this correct before I go and screw up everything I have tried to do.
~Daniel
~Daniel
