vacuum lines
Danbo004
Is there somewhere that I can get the stock connectors for the vacuum system and just replace them all? Or a kit maybe? Seems I can't find the right size at autozone/advanced Really starting to irritate me, mainly the connector from the throttle body to the hard line that connects to the evap cnstr purge valve
dealer didn't even know what i was talking about, really? i had to rig something up from advance auto parts, car started to idle back to normal for about 10 min, then back to rough idle again
dealers are stupid, 99% of the time, its best to know the part number, because the fvck hole on the computer does not know how to use what is in front of him.
I think i may know the part that you are looking for. If it is the T I have a part # for you also. Google it and see if it is what you need. If it is then you have a part #. If its not atleast it tried.
The part # is 12580695 and it is only about $21 at the dealer.
Good luck
i just went to checkers and got all my vacuum lines replaced had to do a little modifiying but its alot better
I just bought the exact same hose a couple days ago. Had to have the dealer look it up on the exploded view of the car. I'll get you the part number tomorrow when I find the receipt.
