Vacuum Line Connections to sensors?
GTPGP98
Okay, so this weekend I replaced the LIM gasket on my 04 GP Comp G. When I reconnected all of the electrical connections, I noticed that nothing connects to the vacuum port on one of the sensors that is located on the rear of the engine. The sensor on the right has the vacuum line connected to it from under the SC snout. The sensor on the left does not have a line connected to it. Does anyone know if a line is supposed to be connected to anything.
Those are both pressure sensors. One is hooked to the engine for manifold pressure the other is open to the air to determine current barometric pressure. It's correct for your year.
