RichardL12
I have an '02 grand prix and I think it has a vacuum leak. When I start it the RPMs rise and drop a little bit and sometimes it idles higher than normal. Also i dont know if this is related but after the car is turned off if you try to start it again it cranks a couple of seconds before starting. I tried spraying brake cleaner to find the leak but had no success. What are all the parts/lines that I should be spraying? Could it be something else? there are no codes in the engine. Thanks for any help
