copgtp
Your ClubGP Liason
Alright, so a little background. The car's lights all worked perfectly fine before I tore it apart 2 years ago.
35w HID low beams, 35w HID fogs, both have upgraded harness.
Putting it back together, I swapped out to new digital slim ballasts, and swapped my old spyder halo's for the newer CCFL halos...........
Alright, so I have the parking light situation pretty much figured out, seems like the LED switchbacks may be causing the problem.........
But I'm still having an issue with the fogs........
when I hit the switch in the cab, the switch doesn't light up........ but the high-beam indicator goes on!?!?!
Also, not getting any power with the switch on to the ballasts........
Checked my HID harness and relay for the fogs, that is in working order.
So this leads me to believe that there is an issue within the hi beam / fog light wiring........ I know they share some wiring b/c when you turn the hi beams on, it usually shuts off the fogs, so it seems to me like something is up...........any ideas or where to start troubleshooting this?
UPDATED: 5/7/12
UPDATED: 5/7/12
