Hi I have a 97 GT.
For the past 2 days it has been giving me headaches.
It started to act funny it would start, run fine, untill i turned on an electrical component, such as a turn signal at which point the tach would go spuratic, the fuel gauge would shoot from 1/2 full to above full, and the dash lights would come on then it would stall. It would start back up if I turned it over and gave it gas, but only if I gave it gas. I assumed it was either power or fuel related. I tested the Battery, its fine. I tested the alternator its fine. I tested the fuel pump, it did not seem to be working so it got replaced. Still same problem. But now when you put the key in and turn it the car turns over has gas and no spark.
SO I tested the fuses and some have power some do not.
Someone said it might be the PCM went bad, but from looking around it seems like it might be the CPS. Anyone have any idea what it might be, I really need to get this fixed before labor day weekend is over.
Thanks
Thanks
