Upper door seal problem
ikester
Hello all....need the name of the seal that is on the top of the door. Mine is bad and I cannot locate them on internet. Also, anyone know how they are attached to door? 2002 grand prix coupe. they are just some strips that are attached to the top of the door that seals the door to the roof. could not locate them on gm parts direct. Any ideas? Thanks Keith
After more searching I think the rubber that is bad is part of the Reveal Molding. Doesn't look like it will be too difficult to replace. Can anyone confirm that a new Reveal Molding comes with new rubber? Also some are listed as BRIGHT. Would that be gloss black? Thanks Keith
Weather-strip top of door
Driver side part#: 10321353 $65.13
Passenger side part#: 10321352 $??.??
GM Parts Direct: 10321353 - MOLDING
Or you can try this:
http://www.grandprixforums.net/dont-wanna-pay-over-100-bucks-fix-your-weather-stripping-34243.html
I found the reveal molding for 71.00 and installed today. Very easy job to do. There was one screw behind the mirror that required the door panel to come off. While I had the panel off I replaced the power window motor that was running up slow. The reveal molding was held on with screws that required the window channel be pulled down remove the screws. All in all it was a very easy fix. Thank you.
