Upgrade Question
bowsox88
What would it take to replace the A/C Heat control to the dual climate control that is in the gtp and also the info center that tells you "oil change, door open,ect" to the digital one?
to go from single to dual climate controll you need to swap the vent tubes behind the dash and some other stuff that makes it not worth doing.
analog to digital DIC is easy though. check the how to section theres a write up.
