2004 Grand Prix GTP
Hello and thanks in advance for anything you folks might have for me.. If this should be posted in another section of the forums or not at all on the forums just let me know and I'll move it.
The story is a couple weeks ago I found I was losing a significant amount of coolant and determined the issue was the lower intake manifold gasket. I purchased the gaskets I needed to complete the job and did that. My father, who has rebuilt a few dozen engines in his day helped me in the endeavor and everything seemed to go pretty well until it was time to start things back up again.
The engine had trouble idling and would rev then lull repeatedly, and the following additional symptoms would occur:
P0101 -
MAF circuit range/performance problem
P0069 -
MAP/MAF Throttle Position Correlation
P0068 -
Manifold Absolute Pressure
So far we have cleaned the MAF sensor, replaced the MAP sensor, looked exhaustively for vacuum leaks, cursed a lot, unplugged the battery to reset the computer, and verified blinker fluid level is above the fill line. I'm sure we've also toyed around with a few other pieces under there that I'm forgetting. We really are out of ideas here, and any and all help would be greatly appreciated.
Thank you!
- Dash computer indicates "Engine Low power"
- Dash computer indicates stability system error (forget exact wording)
- TCS disengages itself
- Engine enters what I would call safe mode, enters a low idle and stops responding to throttle command
- The dash computer "Engine Boost" screen shows about 75% boost active even when the car is not running, and the screen does not change whatsoever when the engine is started until the cascade of failures above show up
- Following error codes register:
P0101 -
P0069 -
P0068 -
Thank you!
