chevyy1212
I know the elbow itself is not cracked. So its where it seals up. Would using some copper RTV around the elbow be a decent fix till it warms up? Or am I screwed again.
Its gonna be close it 40 all week in our area. Better off replacing it instead of fighting with the leaks.
Some people have had back luck with the Dorman elbows and say the GM ones are better. If the new ones leak again I might check into the GM ones.
Make sure you lube the o-rings and double duty would be to put a bead of gray not copper RTV around the the plastic part of the elbow before you install it.
