Typical Gxp trans leak
jteske88
So had a drop or two on the floor so I look for what I been reading about and there it is, what the best way to fix the leak issue
yup, though i heard a powersteering pump got home find out trans is low instantly filled it up. now sounds great. but i couldnt find just the o ring, all i could find was the cooling line and it was in the kit
Well..you have a leak. So let's have you do the work to figure it out. You won't leak much in this process.
Wiggle that black piece back down the tube. All it does is sit there to keep the clip from possibly coming out.
Now..pick that clip out and DON"T LOSE IT. That's a dealer/JY only.
Once the clip is out. Wiggle the line and wipe both pieces down to see if there is an o-ring in there. i know for sure there isn't one on the line.
Or you can try and call me tonight when I'm in the garage. I think I have the fittings and a piece of line in the garage that I could take pics of and tell you what is or isn't in there.
ill be off later and will be messing with this, new problem 500$ worth of packages that jsut went missing from the post office, so pissed currently. thanks bill for all you good advice. i always appreciate it
