turning off headlights
chickenfried
i want to make it so i have to maually turn on my lights with a switch. now they automatically turn on when its dark enough... could someone tell me with wire to cut or unplug?
Open the little cover on the side on the dash by the headlight switch and un plug the little black box. Works on some years, try a search you will find the answer for your year.
Depending on year, you have to unplug the DRL diode and remove the auto headlight fuse in the glove box. There's a panel on the side of the dash, driver's side, that's where the DRL diode is. Some unplugged it, but I went up under with a 10mm socket & extension & unbolted it, then unplugged it.
Mine is a 00 GT, BTW.
on my 05 all i have to do is rotate the light switch backwards once and it disables automatic lights and DRLs.
a newb's $.02
Well in mine if you put the parking brake on one click and shut off the car then start it back up the lights will stay off........until you take the parking brake off that is
