Turn signal flasher
Found out the flasher is part of thr hazard switch. And cuz i have led light and i dont like the quick flash. So im going to try wiring a led flasher inline of the turn signal wiring. And see if that helps
You need the 6ohm (I think) load resistors. Wire one side into the positive wire of turn sign and ground the other. Diode dynamics, ddm tuning, should be able to find them there
Sry for no update. Unfortunatly it did not work. It just made both flash even tho the turn signal wasnt on and the flasher wasnt on. It was grounding and bypassing the switch.
Im just going to use resistors. Found a four pack of them for $10 on amazon
